QAT
SPal
- Bike owned: 893, 929,SP1,NC29,
QAT
HI,
does anyone know if these will fit NC29's ?
http://www.ebay.co.uk/itm/HONDA-CBR-100 ... 415d3372c3
I've got one on my SP1 and it makes a big difference, but unsure if the NC29 throttle grip housing will accept it ?
THanks
SPal
THanks
SPal
SPal
Re: QAT
Suddenly remembered I had old throttle tubes from 893 & SP1 - hunt through garage found 1 ( not sure off which model) but it does fit NC29 throttle grip housing albeit a little tight.
Gonna order up SP1 QAT tube if worst comes to worst can fit SP throttle housing - all good.
SPal
SPal
tanuki
Re: QAT
You need the NSR 250 throttle, fits in the standard housing and works a dream I've been using one for years.
You won't be able to use the return cable though unless you either get one made or find a longer one from another bike.
SPal
Re: QAT
HI Tanuku
Thanks for the info,
What ratio does the NSR grip give ? 1/4 or 1/6 to full throttle
and when you say I won't be able to use the return cable -
For what reason ?
THanks bud.
SPal
I only had a few mins to check the 893 grip last night and it does work, I think that maybe a small amount of work with sander to narrow the bit where the cables go might sort it, as its an old one anyway got nothing to loose !
For what reason ?
THanks bud.
SPal
