Spark plugs very stiff?
				MarkT
Just chaged my plugs but they were very stiff to undo all the way? I did it from the top with a bendy extension. No 3 seems worse and I have tried/removed 2 or 3 times. I am very aware about stripping threads and so tomorrow I might remove them, grease the threads and but them in from the front! Is this way easier?
				dobbslc
Re: Spark plugs very stiff?
In from the top is probably the best way,
Try warming the engine up first as this expands the alloy a bit, make sure you blow / hoover the plug holes out to stop stuff getting in the engine though.
Dobbs
Dobbs
				MarkT
Thanks for that, do you mean lifting the tank or going in fr the front over the dropped radiator ?
Thank you for your time!
greasing them ... ???
put a little bit of coppaslip on them but remember they`ll slip more than usual so you shouldn`t need a heavy hand. do the new ones up and then a 1/2 turn only.
