CAN YOU FIT A 12V14AH BATTERY TO YOUR RVF400???
pagan1001
Hi guys i was just wondering if you can fit any other battery to your NC35 other than the 12V6AH one???.
I was just wanting to get more power for longer as I have brighter lights and an alarm fitted so please help me out and get in touch if i should stick to the specs.
pagan1001
Re: CAN YOU FIT A 12V14AH BATTERY TO YOUR RVF400???
I need the bright lights as i do most of my riding at night and notice this really has an effect on the battery charge (life).
Will it cause any harm or is it no problem at all to replace the standard spec battery???
- Bike owned: VFR400
The only limitation is physical size that fits in the battery space. How does night riding affect your battery charge, does the battery go flat, what wattage headlights bulbs are you running?
The std battery is a 7AH one - YTX7. You can fit a YTX9 in the same slot, it is 15mm taller.
If your chargin system is not able to keep up then I would be checking it out.
Your power comes from the generator.pagan1001 wrote:Hi guys i was just wondering if you can fit any other battery to your NC35 other than the 12V6AH one???.
It supplies 350watts of electric.
What isn't being used up by the electrical system is sent to charge the battery.
It'd be quite difficult to use up the 350watts unles your running someting stupid like 200 watt bulbs!?
The battery is just used to start the bike and supply power when the system isn't charging (at idling and low revs) by 5000rpm the system should be fully charging the battery.
Perhaps you have a dying battery or charging system fault.
Fitting a larger battery wont' solve the problem
