urgent... nc30 compresion..
dannyboy
Bike owned: HONDA VFR400R NC30
Post by dannyboy »
Need an adapter or compression tester for a nc30?'?
Lane
Bike owned: MC21,MC22,NC35's,VJ22
Re: urgent... nc30 compresion..
Post by Lane »
I just made my own one up from an old spark plug, pull the innards out of it and braze onto a suitable tester adaptor et voila!
amaechizzle
Bike owned: NC35
Post by amaechizzle »
braze?
quinn12
Bike owned: yamaha tzr250, honda vfr400r
Post by quinn12 »
gas weld. its called braze. correct me if I am wrong.
lots of things are brazed - think soldering but higher temps.
I'm glad somebody understood that question.. I looked and thought wtf!?
I suggest you goto a workshop.
Buy a compression tester and then goto a workshop and take a sparkplug with you.. ask them to put that thread onto a length of brass rod with a hole through it.. you can attach your compression tester to the other end of this rod.. make sure they put a thread on the other end so you can attach it the compression tester.
Use a rubber o-ring around the seal of the brass rod.
You'll end up with something like this but that will screw into your 30
oldgreyandslow
Bike owned: 1990 NC30
Post by oldgreyandslow »
Here's one a mate of mine made for me
One end is the same as the spark plug thread the other you screw the comp tester into, its the same thread size as a car type plug so you use the standrad comp tester lead. Needs an O ring on the adapter and ist long enough to fit into the spark plug recess without skinning knuckles etc
oldgreyandslow wrote:Here's one a mate of mine made for me
Just what I was thinking of :grin:
oldgreyandslow
And if I wasn't going off on holiday I'd offer to send it to you to borrow
