Carbs
- Bike owned: 1990 nc30
Carbs
I think i have a problem with my carbs ....
Heres the history i have recently given them a total make over using Camo,s guide re-jetted with 118/120 jets (becuase i'm running an Art end can ) and drilled slides and now using 1mm shims on the needles , i reset all idle screw to 2 1/4 turns out as they were all over the place ( 1x3.5 , 1x1.75 and 2x2.75 turns out
After doing the above i now find it boggy on pullaway unless i bring the revs up first and my idle is up and down . I assume from what i have read so far about my symtoms am i right in thinking i need to balance my carbs....
I have decided to buy the carbtune tool so if needed i can balance my carbs propely
do i need to buy a 90° screwdriver aswell ?
I have looked at the guide in the haynes manual not sure that it make sense yet though
just read again i think it makes sense , number 2 carb is basically the one that you set all the others by ...
If i am way off can someone guide me back
Dan
Dan
- Bike owned: RVF400 NC35
Re: Carbs
i would guess an angled screwdriver would make life a lot easier...
you are right in think you only balance three, not sure which one is the benchmark but if haynes is saying number 2 then i guess thats correct. there is a thread about carb balancing recently by royster that goes into where the connections go and the order in which they are done.
- Bike owned: NC35
Re: Carbs
Thought carb balancing was mainly to do with smoother idle :S
P.S. I'm guessing this is a NC30?
Re: Carbs
Firstly make sure all 4 are firing, check each exhaust pipe the same distance from the head. They should all get hot together but please use common sense I accept no responsilbilitu for burnt hands!
- Bike owned: 1990 NC30
Re: Carbs
Been there done that and have the blisters to prove itDrunkn Munky wrote:Firstly make sure all 4 are firing, check each exhaust pipe the same distance from the head. They should all get hot together but please use common sense I accept no responsilbilitu for burnt hands!
Re: Carbs
Here's the latest my carbs are now balanced after loads of agro ( like trying to eat an egg with a shovel ) getting hand in that gap i will be buying the tool if it needs to be done again , do they wonder out of balance if so how often would/should you check them ????
my results were after fittng carbtune carbs 2 & 4 only needed a tweak
then i adjusted 1 to 3 this was a bit of a pain then time to balance them all together sort of thing and this is wot happened 3 came up but 1 dropped off so i 2 3 & 4 done
then had to re-adjust 1 to get this
it looks pretty good to me
- Bike owned: NC35
Re: Carbs
How the hell did you fit your hand in there??carpman wrote:getting hand in that gap i will be buying the tool if it needs to be done again
How's it running now, very interested to see the results!
Re: Carbs
@ amaechizzle
It was tight i could'nt get my hand in with the socket on at same time so ended up using some long nose pliers with 7mm 1/4" drive socket with adapter to hex in it and did it that way in the end , i must admit it does feel 100% better on takeoff and idle is now where it should be about 1300rpm
- Bike owned: NC35
Re: Carbs
Damn, I've been putting off balancing, as I didnt wanna fork out for the gauges
I've got the special tool... I guess I cant really put it off any longer after your results!
