nc23 flaot bowl screws?
- Bike owned: CBR400RR NC23
are they a m4 or a m3? i know there length, but i want the correct size as i want to get stainless steel for them :)
Re: nc23 flaot bowl screws?
Might tell you in the parts book but M3 is really small so they're probably M4.
You might want to get the carb top, airbox rubber and carb rubber ones too.
Get allen cap head bolts
m4 dan, i use M4 x 15mm and 12mm
cheers rick :)
If you use the correct screwdriver you won't break the original ones...
allen cap heads are much better than screwdriver :)
I prefer the screws.
I can use the same screwdriver to undo the airbox lid, airbox lower, carb clamps and carb screws rather than need to switch tools..
i have airbox lid and air filter done with stainless allen bolts.
I eventually want to get the inlet rubber clamps in stainless with allen bolts and any other little screws on the carbs such as choke bracket and tickover adjuster.
Then it'll be time to revamp the rear in all stainless :)
