calling all decent electrical minded !!!!!
- Bike owned: nc23,rs250
Hi guys and gals, as tittle says ive ran in to a little problem, as you probaly know ive been working on a nc 23 project and its going great that was till we changed the speedo for a digital dash, ive hooked everything up oil neutral etc, all seems fine till we turn on the lights( we used all original wiring and lights ) when ither lights turned on full, dip the dash seems to ither trip or resest it self. ive been working on this for a week now i seem to have drawn a blank, as i know a few of you have installed digital dashes i bow down and ask for your help :)
Im confident there is bound be a few you on here that can through me some ideas and i look foward to reading the posts.
cheers guys and gals
Re: calling all decent electrical minded !!!!!
Without seeing how you've wired it it hard to say definitely the answer but it sounds like the headlamps are momentarily drawing a lot of power and causing the dash to crash/reset.
If I was sure that the dash was wired in correctly I would put a Capacitor across the +ve and gnd supply lines. This would charge up when the dash was powered up and would hold the voltage up if there was a momentary drop in the supply voltage due to headlights drawing power.
something like this bad boy (35v rated 1000uf)
http://www.rapidonline.com/sku/Electron ... 38/11-1250
Maplin will stock similar but just cost a bit more (quid or two). It just has to be rated over 12v...but most are 16 or 35v which is fine.
Disclaimer: This is what I would do if I encountered the problem you describe, but it may not be the correct solution for you. If you are unsure about anything above please check with an qualified electronics engineer.
- Bike owned: CB-1, MSX125
It's a good idea, but I would say that if it's right then it points to a bigger problem, ie. dead battery.barryfzr wrote:Without seeing how you've wired it it hard to say definitely the answer but it sounds like the headlamps are momentarily drawing a lot of power and causing the dash to crash/reset.
Thanks for the replys after reading may be the battery, i went and charged it till was fully charged, after that reconnected it and started up the bike and success the lights worked without a problem :). i guess i need to have more confidence in my electrical skills(doesnt help when u got ya dad looking over ya shoulder shaking his head saying its the wiring or your doing it wrong lol) thanks again for all those who replied
