GK76 Earthing Points
				chris_psmith
Trying to work out the main earths for the bike, big earth to back of starter, anyone know the other earthing points?
Chris
						Chris
				morris147
Re: GK76 Earthing Points
One on the rhs of the frame, around where the coolant housing bolts on.
				chris_psmith
thanks, i will clean them up this evening and see if it helps.
Chris
						Chris
				chris_psmith
Had a look, i have an earth wire connected to the coolant cap housing on the front face (so the black plastic side), assuming this is wrong..... where should it go to, frame?
Chris
						Chris
				morris147
Is that the single connector on next to the coolant hoses?
If so thats the thermostat sensor.
				chris_psmith
No, connector to sensor is in place, it is an earth wire (black and white) coming out of harness on right, it had been connected to plastic rad cap housing, now connected to frame where mount for rad cap comes off.
Chris
						Chris
