VFR400 NC30 fork problem
Posted: Thu Aug 11, 2011 7:46 pm
Hello,
I have recently noticed that their is an issue with the damper adjuster on one fork. One clicks when adjusted and the other (suspected issue fork) does not and turn a lot less than the other. Is this an easy fix or do I need a new fork top nut. I see Rick Oliver does them but they are pretty expensive! Also considering the Rick Oliver upgrade kit so taking apart is not an issue.
