NC23 charging problems.....
Just picked up a 1990 NC23, bike is a good condition apart from it wont charge, the battery goes flat as soon as, it wont charge if you scoot around on the bike, the system is showing a charge of 11-ish volts when the bike is running....not the usual 13 - ish...
Bike is fine with another battery jumpleaded across - revs fine but splutters, coughs, & runs flat & stalls without??
Turing even the sidelights on will make matters worse, would this be altenator probs or the regulator/rectifier playing up??
Any one had similar probs??
Re: NC23 charging problems.....
veefer400 wrote:Just picked up a 1990 NC23, bike is a good condition apart from it wont charge, the battery goes flat as soon as, it wont charge if you scoot around on the bike, the system is showing a charge of 11-ish volts when the bike is running....not the usual 13 - ish...
Needs a new Battery by the sounds of it.
Suggest get that wired up, before anymore rennovations!
(you will need a new battery at some point anyway, so why not take the pain now>>)
Martin
check the plug to the reg rec...look for burnt plastic,if so,replace that also
stimpy
stimpy
Knackered battery would have been my first port of call, but its only charging around 11ish volts anyways?? Even with a good battery this would soon run flat, should be around the 15 volts mark??
Got it back home, will give it a wash down and inspection Thursday, see if anything strange is going on.... Have got three keys for it, one fits the ignition, one fits the tank, havnt worked out what the third one fits, possibly the pillion seat - should there be just one key for everything??
veefer400 wrote:Knackered battery would have been my first port of call, but its only charging around 11ish volts anyways?? Even with a good battery this would soon run flat, should be around the 15 volts mark??
If u have a good V5, ur be fine!
Could be crash replacements, or crap keys cut
Martin
Cool! Where is the Reg/Rectifer to in these, in the tail unit somewhere i presume?? Anyone got a spare Haynes for sale??
new battery first without a shadow of a doubt
- leopard_pagan
if the voltage is low, doesnt that suggest a buggered Reg/Rec?
i know when i had starting issues with my NC29 a few yrs back, bike shop checked the voltage and it was low as bike idled, they said reg/rec straight away. turned out to be a burnt wire at the reg/rec connector, cut and re-fitted crimp and all has been fine since.
- SHimmer45
- Bike owned: GPz500s KR1 KR1-S
needs to be around 13-14v for it to charge properly id say.
Stripped the battery out y/day, was bone dry??!! Have refilled and charged, will see what happens...
