Track bike ignition question
vfrman
Bike owned: NC30, 1098s
Post by vfrman »
So, I am replacing the key ignition on my track bike with a toggle switch. Looking at the diagram it should be ok to splice the blue/orange wire with the red/black wire right? They both go from the ignition to the fuses. The red wire comes from the main fuse and battery. Also, since the blue/orange wire power the fan circuit, I can just not use this one, since I don't have a fan installed.
Can someone tell me if I am right or wrong on these two ideas?
Bike owned: VFR400
Re: Track bike ignition question
Post by magg »
If you are not using the fan then there is no need to connect the blue/orange wire at all. Toggle switch just needs to connect red to red/black to energize the ignition circuit.
vfrman
Post by vfrman »
What I thought.... Cheers for the confirmation! Now to break out the soldering iron...
Lane
Bike owned: MC21,MC22,NC35's,VJ22
Post by Lane »
Just make sure it has a spring loaded toggle to save your starter motor.
If you aren't running one then ignore me.
Bike owned: VFR400
Post by magg »
Starter motor is controlled by the starter switch which is different to the ignition switch. Ignition switch should be normal on/off so that battery power is applied continually when in the on position.
Cammo
Post by Cammo »
I find it easiest to use the kill switch for the ignition rather than add another switch.
Bike owned: VFR400
Post by magg »
If you intend to use Cammo's solution you will still need to connect the red & red/black wires together, with or without a switch.
vfrman
Post by vfrman »
Got is sorted. Thanks all. I should take a pic....
