Hmmm...issue with rear brake pad retaining pin
ludacris
- Bike owned: NC35
Ok so the hex cap on the rear brake pad retaining pin has been rounded off (the hex bit won't turn the bolt). I can undo the caliper bolts and slide the caliper forward but that won't let the caliper slide off
Need to get the caliper off and this pin needs to be removed first so any suggestions?
Cheers.
Cheers.
- Hadies
Re: Hmmm...issue with rear brake pad retaining pin
Huh? You can't get the caliper off without removing this pin?
That pin only holds the pads.
lizard821000
what he says^^
the pin only needs to come out if removing the pads.
ludacris
- Bike owned: NC35
yeh i want to clean up the rear caliper and change the pads but the caliper just wont come off even with the mounting bolts removed...i can slide it but it just slides around the disc. can't actually pull it off for some reason
arsey30
- Bike owned: ftr223 650 bros
Lever the pads back into the fixed and sliding caliper, there may be a ridge on the disc edge.
hardnutdvd
- Bike owned: RVF400 NC35
when you say the hex cap on the retaining pin. is is actually the head of the pin thats rounded or the small lug that screws in on top of the retaining pin
number 18 on the diagram
http://www.cmsnl.com/honda-rvf400rr-nc3 ... t/F12.html
if it is the actual pin, have you tried banging a torx bit into the rounded head
ludacris
- Bike owned: NC35
nah its not the slotted cover, its the head on the retaining pin where I believe a 5mm hex bit should go in. I'll try your suggestions.
lizard821000
I had to use a impact tool on my pin, loclite or somin was on it!
- BillingCBR
Probably just corrosion liz :) it's in a pretty good place for getting manky.
I had a similar battle with another bike, ended up cutting a chunk out of the pin itself to the pads could come off, then wrenching it out with a set of molegrips, hopefully hammering a Torx bit (as opposed to the allen bit it should have) wil jar it enough to loosen it, and give enough bite to undo it without resorting to (serious) violence.
ludacris
- Bike owned: NC35
yeh tried the torx bit suggestion but it didn't work so I went hammer time on the caliper and it came off (begrudgingly of course)...so I then took an angle grinder to the pin for some self satisfaction...now that it's off, I think an easy out should do the trick
