CBR400RRR - UK spec lighting
- Bike owned: 893, 929,SP1,NC29,
HI,
I've got a 94 CBR400RRR
I want to try & modify the lighting wiring so that :
1 - I use a 893 Headlight switch - so that lights don't come on all the time with the ignition
2 - I can run on parking bulbs only
3 - Run UK spec Headlight bulbs - I believe an additional low beam relay is required !
Been a v.long time since I had an import VRF400RR 89, but from what I remember this did what i want on the cbr,
Does anyopne have wiring diagrams for both bikes so I can compare & work out what wiring mods i need to carry out
SPal
SPal
- Davez29
- Bike owned: NC29 forever
Re: CBR400RRR - UK spec lighting
This thread may help or hinder you but its the best I can come up with. Dont know anything about your on/off problem though.
viewtopic.php?f=26&t=21727
CHeers for this, i have a 893 headlight switch witch i plan to use so will check out the wiring
Mant thanks ##
SPal
Mant thanks ##
SPal
