Good mechanic or garage in the North West?
Concrete Jungle
Bike owned: NC 35
Post by Concrete Jungle »
My attempts to get my RVF running right have failed, so I have decided to pay someone more mechanically minded than me to try and put it right. I know of Fastline in Preston, but I hear a few less than inspiring tales about some of the work they have carried out. Is there anyone on GB who could recommend someone for me to take the bike to in the North West who knows their way round the RVF?
Alex_ludd
Bike owned: Giantco 125, ZZR400n , NC30
Re: Good mechanic or garage in the North West?
Post by Alex_ludd »
where abouts are you based mate if your reasonably close to me i can come and have a look at your RVF im not a mechanic but 2 heads are better than 1 and i've encounted most issues with my 2 NC30's :grin:
Do you have some more details of whats wrong with your bike
alex
vr46
Bike owned: All sorts
Post by vr46 »
What are the symptoms?
abrmoto
Bike owned: RVFx5,SP1,MV F3,C90,Firestorm
Post by abrmoto »
Concrete Jungle
Bike owned: NC 35
It went from starting on the button every time, to needing full choke and a bit of throttle to start. The revs 'hunt' up and down at times with the throttle held open at say 5k, revs will intermittently go from 4k to 6k, back to 5k without moving the throttle. Putting the choke in after 5/10 mins the bike just dies in 5 seconds, engine revs fall and it cuts out. It has started cutting out when rolling off the throttle when approaching a junction / roundabout. It will restart after cutting out.
Had new plugs, battery and carbs cleaned / balanced at the end of April, did 800 miles fine then the problems started. I changed the oil / filter last week while it was off the road. Thought it was perhaps a fueling problem so had the tank off to check the fuel line and vacuum, both look ok. I am near Preston.
yazza54
Post by yazza54 »
My dad's friend has a motorbike garage in middleton -
12-14 Lodge Street
Middleton, Manchester, M24 6AL
Telephone/Fax: 0161 654 4744
Only a small shop but Dave knows his stuff, is very thorough and no rip off merchant.
Reg/Rec????? i only say this as it ran fine with a new battery for 800 miles, just enough time for a dodgy reg to murder the new battery and the symtoms show their heads again
Concrete Jungle
Bike owned: NC 35
I have not got round to testing those just yet.
Get it tested, sounds like the genny is failing slightly..
cbr400rrn
Bike owned: NC29 CBR600F
Post by cbr400rrn »
Fastline now own 'North west superbikes' which is at the top of New Hall Lane, Preston.
The place they were in before is going to be knocked down i have been told.
Just a little info for you all.
