Strange starting problem
Andy_Edw
Post by Andy_Edw »
I went out for about a 1hour on my RVF,Stopped for around 10mins,Went to start my bike up and it wouldn't start on the button? But it bumped fine..Sometimes it starts on the button then it doesn't,Only started happening today,Any ideas?
domski1
Bike owned: Rvf nc35
Re: Strange starting problem
Post by domski1 »
When you say doesn't start on the button does the engine spin over?
Andy_Edw
Post by Andy_Edw »
Nope It just clicks like the battery is dead,But the battery has good charge
hunter
Post by hunter »
Check the solenoid connections.
Bike owned: VFR400
Post by magg »
If solendoid connections ok then soleniod internal contacts probably need cleaning. You might be able to disassemble the solenoid & clean the contacts, not tried it myself as have not had the problem yet.
amaechizzle
Bike owned: NC35
Post by amaechizzle »
Tried taping the starter motor solenoid while the button is pressed. It's an old school trick, to try and get the solenoid contacts to create a good contact.
Andy_Edw
Post by Andy_Edw »
Cheers for the replys,But it hasn't happend since i posted this. Pretty strange
wallie_555
Post by wallie_555 »
I had this a for a while last year, turns out charge wasnt going back into the system. Turned out to be the wires going to the reg/rec.
hardnutdvd
Regular Member
Bike owned: RVF400 NC35
Post by hardnutdvd »
i would be inclined to give the charging system the once over.. use the step by step guide in the documents section
Lane
Bike owned: MC21,MC22,NC35's,VJ22
Post by Lane »
Andy_Edw wrote:Cheers for the replys,But it hasn't happend since i posted this. Pretty strange
The likelyhood of it reoccurring is directly proportional to the secludedness of your whereabouts at the time!
