Page 1 of 2
NC30 fork leak
Posted: Fri Jul 22, 2011 9:58 pm
by Hadies
I fitted the RO fork kit recently to my early type forks and have found the fresh blue suspension fluid seeping out the back of the fork pinch bolts.
The fluid isn't coming out of the drain bolt on the back of the legs so it must be coming from the bolt on the bottom of the leg. Odd how it wasn't leaking before and now it is and I haven't touched this bolt.
Anymoo, I've checked out the parts manual and theres a 'special washer' under that bolt. What is this washer? Going to use some PTFE tape to make sure it doesn't leak again.
Hadrian
Re: NC30 fork leak
Posted: Fri Jul 22, 2011 10:16 pm
by Delboy
Think it's just a copper washer.........
Re: NC30 fork leak
Posted: Fri Jul 22, 2011 10:30 pm
by Hadies
Good stuff. Any idea what size mate?
Re: NC30 fork leak
Posted: Sat Jul 23, 2011 12:12 am
by lizard821000
i orderd some brand new copper washers for those bolts mate but never used them cos i fitted some later type ones in end. david silver they was like 50p or somin silly, i can messure it if you want tommorrow.....or send you the one i never used. :peace:
Re: NC30 fork leak
Posted: Sat Jul 23, 2011 12:15 am
by Hadies
Quality. I'd appreciate it if you can measure it up mate and if it's a size I can't source locally I'll give you shout. Thanks
Re: NC30 fork leak
Posted: Sat Jul 23, 2011 12:18 am
by lizard821000
ill do it in morning lad ;)
Re: NC30 fork leak
Posted: Sat Jul 23, 2011 9:06 pm
by Hadies
You manage to get these measurements Shaun?
Re: NC30 fork leak
Posted: Sat Jul 23, 2011 9:34 pm
by hunter
If you have copper washers in your forks,take them out get a piece of wire bend a hook at one end,
hang the washer over a gas ring or blowlamp untill cherry red, then drop in cold water you can then re-use washers.
Re: NC30 fork leak
Posted: Sat Jul 23, 2011 9:44 pm
by Hadies
Cheers hunter. I'll drain the fluid and whip that bolt out and give this a go. Hopefully that'll stop it seeping. Is there any other place it could be leaking from? Thanks all
Re: NC30 fork leak
Posted: Sat Jul 23, 2011 11:18 pm
by lizard821000
oh fk mate, lol, i forgot. if you still want the messurment ill do it first thing . :oops:
