Alternative to a dremel?
oldgreyandslow
Bike owned: 1990 NC30
Post by oldgreyandslow »
This may be the wrong form for this question, apologies if it is
Anyone used these as an alternative to a dremel
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
jim157
Admin NWAA
Admin NWAA
Bike owned: A few small ones
Re: Alternative to a dremel?
Post by jim157 »
I'd be inclined to pay a bit more and buy a Dremel. I got a 200 series off the bay about five years ago for a tenner and it's pretty good. The only drawback I found is that it only has two speed settings (15000 & 35000), which can be a bit inconvenient for some jobs. If I were to buy another one I'd go for the 300 series as it has a variable speed controller, which would be handy if you are working with plastics. You can pick them up for about £40 with the accessory kit.
AUTOEXEC.TWAT
amorti
Regular Member
Bike owned: CB-1, MSX125
Post by amorti »
I have a Clarke dremel-type tool from machine mart.
I have rarely found a job where it could actually be described as useful. In almost every even that I have tried to use it, I have ended up giving it up, and grabbing for the proper angle grinder, or a battery drill with brass brush attachment, or a hand file, or wet and dry paper ... I really don't see the value in these tools.
Can anyone explain a purpose for them where it really was the best and only imaginable to use? Only thing I can think of is engraving and how much of that does your average biker do?
Chrissy_J
Bike owned: VFR400Z NC21
Post by Chrissy_J »
I suppose the product referred to in the link, would be OK for simple jobs... There are Dremels, and Dremel-like tools, and you always get what you pay for as I have learned to my cost!
I had a cordless Dremel (forget the actual model) and it was OK but the battery went, as they always do, and I couldn't get a replacement. I used it to cut a slot in the end of exhaust studs, so I could use an impact driver to remove them... I used it to grind down chain link pins when shortening drive chains, as well, and to clean out brake caliper piston bores and grooves.
My verdict: they're fairly specialised tools and you can live without one, but they're useful to have in the shed. I need another one, actually....
amorti
Regular Member
Post by amorti »
Chrissy_J wrote:I suppose the product referred to in the link, would be OK for simple jobs... There are Dremels, and Dremel-like tools, and you always get what you pay for as I have learned to my cost!
Both cutting jobs would be easier and quicker with a disc cutter.
The brake groove I would probably have to grant you, but toothbrush sized brass brushes are much cheaper or you could fit a brass brush to your cordless drill.
lizard821000
Post by lizard821000 »
the only time i found my dremal useful was when i needed to cut into my fairings to fit some crash bungs, everything else i tend to use a grinder or drill+attachments
Username
Bike owned: VFR400RK, VFR750FK, VFR750FH,
Post by Username »
Very good for removing inner bearing races. Just grind a small slit in the inner race not all the way through, insert a cold chisel and give a sharp tap and the race will split and allow easy removal.
Morespeedvicar
Post by Morespeedvicar »
Hi, I have a dremel cordless it was the first cordless one they made i think, must be 10 year old, still goes great. Also have a clarke and a draper one. the draper isnt as well finished as the clarke, but both work well. If you have a compressor you could get a air dye cutter, there good and wont burn out if you get a bit heavy handed.
I use them all the time on various things from cutting seat mounts out a cars to porting my model RC car engines!
Ian
Ive had 2 dremals, both of them packed up on me :down:
I now use one of these http://www.tooled-up.com/Product.asp?PID=14196
sorry not much help unless you have a compressor
