zxr 400 usd forks on nc29
sparkie1989
hi was just wondering if anybody knows if some zxr 400 forks would fit a nc29 or will i have to change the complete front end calipers wheel yokes etc
amorti
- Bike owned: CB-1, MSX125
Re: zxr 400 usd forks on nc29
They are completely different, you would need everything. Forks are bigger so need yokes. Discs are bigger, so need 310mm discs. At that point you might as well do the whole thing as a complete swap. I have no idea if it's possible to fit the forks to that frame as the headstock may or may not be too different.sparkie1989 wrote:hi was just wondering if anybody knows if some zxr 400 forks would fit a nc29 or will i have to change the complete front end calipers wheel yokes etc
Try late fireblade forks if you want performance upgrades, but they are still RWU forks. 96-7 forks = fully adjustable, use your wheel and discs, fit Fireblade / CBR600RR master cylinder and calipers.
tanuki
and if you want USD RVF was pretty easy to do, you will need the yokes, forks, calipers and someone who has a lathe or an angle grinder and a massive hammer.
