nc30 throttle cable push/pull
krisztian_andre
Bike owned: MG v35 II, NC30, MG NF Mil.
Post by krisztian_andre »
I found these two throttle cables on ebay, what is the difference between push and pull, which one do I get?
http://www.ebay.co.uk/itm/Throttle-Cabl ... 19c6cfabfc
http://www.ebay.co.uk/itm/Throttle-Cabl ... 43a82939d9
amorti
Regular Member
Bike owned: CB-1, MSX125
Re: nc30 throttle cable push/pull
Post by amorti »
They work as a pair. Best to replace both at the same time, usually.
shereen
Bike owned: VFR 400 NC30
Post by shereen »
amorti wrote:They work as a pair. Best to replace both at the same time, usually.
What he said 8-)
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car
porndoguk
Post by porndoguk »
i only use one!
TJenkos
Post by TJenkos »
I have one of these, not sure which, but it's brand new and yours for a fiver. Will just have to order the other, I'll check which when I get home if you're interested
mick.mh2racing
Post by mick.mh2racing »
porndoguk wrote:i only use one!
I only use one as well. The throtttle is on a return spring anyway so completely un necessary.
How hard can it be?
porndoguk
Post by porndoguk »
yup, and if it got stuck, id pull the clutch and hit the kill button problem solved ;)
Cammo
Post by Cammo »
I only use the pull cable on my nc30's too.
krisztian_andre
TJenkos wrote:I have one of these, not sure which, but it's brand new and yours for a fiver. Will just have to order the other, I'll check which when I get home if you're interested
Thank you for the offer, but I'm in thailand and with the postage...
I'll try to source the cables locally.
Chrissy_J
Bike owned: VFR400Z NC21
Post by Chrissy_J »
krisztian_andre wrote:I found these two throttle cables on ebay, what is the difference between push and pull, which one do I get?
You get both of them, if you want the throttle to work as designed. The cables are about the same length, but they have different shaped 'noodle' tubes that screw into the throttle housing.
The supplier should know what you need; if you aren't sure that he does, you could maybe photograph the originals and email the pics to the seller. Thailand to Wales is a long way to send things back!
Having two throttle cables is overkill, but there's probably a good reason why Honda designed it that way...
But then what do I know, I use a single cable and make my own... :o
