What size is NC30 brake MC?
- Bike owned: Hondas, Ducati, Suzuki, Vespa
Hi guys, what size is the brake MC, 19x18 16x18 19x21 any help appreciated.
Cheers,
Adrian
Cheers,
Adrian
- Bike owned: CB-1, MSX125
Re: What size is NC30 brake MC?
14mm.
If you want to start getting radial master cylinders, you would be best off to get an RO kit and fit CBR600RR front calipers, these are biggest so the most compatible with the later tech.
If you want the radial master, get the smallest one which is meant to work with dual calipers, as '30 calipers are very small-bored.
Thanks, do you know what the leverage is in mm?
Cheers.
Cheers.
You can't do a direct conversion from standard 14mm axial cylinder to radial.999Gomerz wrote:Thanks, do you know what the leverage is in mm?
Cheers.
