Front Sprocket Housing- now can't select gears!
- Man_Named_Dave
- Bike owned: NC30(K)
In preparation for changing sprockets and chain I just opened up the sprocket housing...
And hoo-boy! is there a lot of gunk in there! Any tips for
a) getting the housing super-clean and
b) keeping it that way?
Last edited by Man_Named_Dave on Sun Jul 03, 2011 2:45 pm, edited 1 time in total.
Delboy
Re: Cleaning & Maintaining Front Sprocket Housing
When I changed my sprocket, got an old screwdriver and scooped all the old crud out (there was a lot
), then spray gunk and an old rag to clean the rest then wd40 for that nice finish (not that anyone will see it except you).
To keep it clean you'll have to remove the cover now n again to clean it, maybe combine it with a yearly/winter clean?
- Man_Named_Dave
Cheers Derek,
Having seen what it's like, I'll definitely be cleaning it out on a regular basis! Gotta get hold of some molybdenum disulfide as well.
lizard821000
yeah, basicaly just scrape it right out, time n patients and wd40 i used, think i used some degreaser too but watch out where you spray it, dont know if theres anything that can be fudged by it , i sprayed it onto a plate brush pole (kitchen plate cleaner thing lol) and went mad.
- Man_Named_Dave
Re: Front Sprocket Housing- now can't select gears!
Well I've cleaned it out, but after re-attaching the cover and adjusting the clutch cable I can't get through the gears properly!
Sometimes it'll only shift down to 1st and refuse to go up from neutral, other times it'll get up to 5th but no further.
Is this a classic case of 'clutch not disengaging?' I've been using the Haynes guide for clutch cable adustment.
thrasher
- Bike owned: nc30
did you remove the gear change linkage by any chance?
- Speedy
- Bike owned: RVF400RR, ER6n
Make sure part number 9 on this link: http://www.cmsnl.com/honda-vfr400r3-199 ... _0800.html is still in there.
- Man_Named_Dave
Cheer guys, got it sorted in the end.
- iDemonix
- Bike owned: '92 NC30
Well what was it in case anyone else has this problem?
lizard821000
failed thread
