Page 1 of 2
help rearsets
Posted: Fri Jun 24, 2011 6:56 pm
by joshmega
just put on a set of dimond rearsets
brake side however the lever is sitting far to low for me to reach i have fully adjust the screw to make it as low as it will go but still no luck any help?
Re: help rearsets
Posted: Sat Jun 25, 2011 1:02 pm
by mick.mh2racing
When you say you've adjusted it do you mean you shortened or lengthened the connecting rod?
If not that's the way, but a picture would make it easier to understand.
Re: help rearsets
Posted: Sat Jun 25, 2011 3:50 pm
by Jamboy
I to are having this problem I'll get a Pic up shortly
Re: help rearsets
Posted: Sat Jun 25, 2011 4:15 pm
by Jamboy
Here is a couple of pics I think your after.
The lever does sit really low at full adjustment.
Re: help rearsets
Posted: Sat Jun 25, 2011 5:05 pm
by skinnydog0_0
Yer does seem a bit low, but for me that would be better as i never use the back brake ;)
Re: help rearsets
Posted: Sat Jun 25, 2011 5:37 pm
by joshmega
Yeah thats the proplem mine is even lower than that though i have the original joint which is used with the standard sets
Re: help rearsets
Posted: Sat Jun 25, 2011 10:00 pm
by joshmega
mine look like that
Re: help rearsets
Posted: Sat Jun 25, 2011 10:03 pm
by Jamboy
looks like there is still some room for adjustment there.
Re: help rearsets
Posted: Sat Jun 25, 2011 10:07 pm
by joshmega
thats an example of found of someone else with the proplem mines a tiny bit better but not good enougeh
Re: help rearsets
Posted: Sat Jun 25, 2011 10:08 pm
by Jamboy
I'm going to give this a coat of thinking about tomorrow while I'm doing some more work on mine because there must be a better way of doing this.
