NC30 Fuel tap
- Bike owned: ftr223 650 bros
NC30 Fuel tap
Can anyone say if the Cover set 16953 449 751 [16953 ME5 025] comes complete with the 2 diaphragms , spring and spacers, as it is not clear from the parts list drawing.
I would expect so, as the diaphragm wears more than the covers, but want to be sure before ordering.
Thanks,
Dave.
Thanks,
Dave.
Re: NC30 Fuel tap
http://images.cmsnl.com/img/partslists/ ... 0_e61d.gif
that any clearer?
still hard to tell though, i would imaging part number 2 is what your after would contain the diaphram and spring,
have a work with rick oliver dave, im sure he knows the answer
that any clearer?
Re: NC30 Fuel tap
That was the drawing I was looking at, but I will speak to Rick as I have an odd problem on a friends nc30.
The fuel flow is a fast trickle with engine running and a new vacuum pipe connected, and then the engine eventually stops with empty carbs.
It runs Ok with a bottle fed supply.
I have disabled the fuel diaphragm and the flow is now full bore and the engine now runs well, but if left ticking over for a while, the revs slowly die and the engine stops as before, but now it starts and runs straight away.
Dave.
Dave.
Re: NC30 Fuel tap
I'm pretty sure the fuel tap is only available as a complete unit (and fairly expensive).
Rock Oliver sells a tap rebuild kit, might help out in this situation.
Tank breather problem perhaps? Try opening the fuel tank when the engine is struggling, to see if there'a a vacuum in there.arsey30 wrote:I have disabled the fuel diaphragm and the flow is now full bore and the engine now runs well, but if left ticking over for a while, the revs slowly die and the engine stops as before, but now it starts and runs straight away.
Re: NC30 Fuel tap
Fuel is now flowing freely and engine runs well but just dies after ticking over for a while, but starts up straight away and picks up perfectly.
Dave.
Dave.
- CRM
Re: NC30 Fuel tap
Could be, but it restarts on all 4, and it will run OK on on 3.
A plug was fouled a while ago [flooding?] but it run well on 3, starting ticking over, and pick up.
The carbs have beed cleaned and checked since, including equal float bowl fuel capacity.
I don't have the bike in my workshop, but visit the owner and work ouside, so a bit more tricky to evaluate the problem.
I may get the bike to my place in the end.
Dave.
Dave.
Re: NC30 Fuel tap
The tap diaphragms looked OK, and fuel flowed but not full bore, so new diaphragms have been fitted.
The bike now runs perfectly.
Dave.
Dave.
