Rad fan dismantleing
my radiator fan is rust central, obviously not the fan itself thats plastic, that would just be silly. But all the metal is regressing back to iron ore.
Managed to get the main unit from the surround, but want to get the electric motor bit out of the metal case, so I can soak that. Any ideas ? When the main unit is away from the surround the back comes off and you can see the motor, it spins up freely, and it does (did) work. I don't wanna force it, in case I'm forcing it incorrectly, and then break.
What should I do.....
What about aftermarket ones ? I have tried but cant find anything. What about a PC fan ? probably would get too hot with it being between rad, exhaust and engine.
Thanks in advance.....
Re: Rad fan dismantleing
hold the fan still, with you hand holding the blades,
8-10mm socket undo the nut, anti clockwise,
pull the fan off
the metal top hat under the fan blade needs prising off with a scrwdriver bit by bitdo it 12, 6, 3, 9 o clock.
remove the felt thats behind it
remove the little circlip
unscrew the motor from the fan bracket 3 x 10mm nuts, maybe rusted on
undo the 2 or 3 m5 phillips screws on the back of the motor,
at the bottom where there is a square drain hole get a screw driver inthere, and pry the cases apart
it maybe stiff there is a white grease/silcone sealant, these cases will be held by this and MAGNETISM
makesure you dismantle this bit in a clean area with no metal dust about etc
done
refitting is a the same as before but a little trickier as the brushes are a bugger to push back in due to the shape of the armature, youll need 2 pairs of hands for this, i got the mrs to help
pull the fan off
done
ahhh I see, thank you very much. I had done everything except the top hat thingo.
Best to check on here first before I do something I regret......
When Im ready to refit I'll let you know, if your Missus isnt to busy.....
i keep her locked in the kitchen shes safe in there, you wouldnt wanna meet her!jay3 wrote:ahhh I see, thank you very much. I had done everything except the top hat thingo.
