NC35 tail
Guerrero
Bike owned: VFR400
NC35 tail
Post by Guerrero »
I got a NC30 track only, and I need a new tail.
I found a race NC35 tail... will it fit the NC30?
porndoguk
Re: NC35 tail
Post by porndoguk »
Guerrero wrote:I got a NC30 track only, and I need a new tail.
not without modifications
ideally youll need a 35 subframe and bolts
Guerrero
Bike owned: VFR400
Re: NC35 tail
Post by Guerrero »
What are the differences between the 2 subframes?
Is the NC30 longer?
porndoguk
Re: NC35 tail
Post by porndoguk »
Guerrero wrote:What are the differences between the 2 subframes?
Is the NC30 longer?
no its the mounting points, size is about the same, the undertray is also the same.
the 35 on has the 2 bolts at the front on show where as the 30 has 6!
the 35 has 2 mounts that go under the seat, but youll need to fit a brace accross the nc30 frame, above the battery
also the front mounts screw into the subframe bolts, (M6 thread) and the nc30 bolts arnt made for this but could be done i guess, but its a lot of hastle to fit a seat unit, as i say the easiest option is to get a 35 Subframe. there cheap enough,
Cammo
Re: NC35 tail
Post by Cammo »
I've fitted a few nc35 race tail units to nc30's, you just need to drill a few more mounting holes in the seat unit, and make use of the available threads in the subframe. it's not a big job.
No biggie for a track bike but it could get ugly on a road bike.
Guerrero
Bike owned: VFR400
Re: NC35 tail
Post by Guerrero »
I guess my main concert was the seat area... it seens like the NC30 has more room, compare to my old RVF.
If the only mods are new mounting holes, that's easy...
