Flywheel marks. What they mean ?
PARUS
Post by PARUS »
Flywheel has 3 marks.
1. O| - ????
2. F| - ????
3. T| - TDC.
What these first and second marks mean ?
tanuki
Re: Flywheel marks. What they mean ?
Post by tanuki »
The TDC on number 3 means top dead center.
PARUS
Post by PARUS »
tanuki wrote:The TDC on number 3 means top dead center.
Yes, I know what TDC mean. What is the purpose for the 1 and 2 ?
PARUS
Post by PARUS »
1. O| - Mark that allow to check exhaust valves clearance for 1-3/2-4 cylinders.
2. F| - ????
3. T| - TDC.
So, what is F| ??
F might be the "firing" point of the stroke. Does it become before TDC on the flywheel?
PARUS
Post by PARUS »
CMSMJ1 wrote:F might be the "firing" point of the stroke. Does it become before TDC on the flywheel?
All I find that crank trigger wheel has same mark - F, and when you align F| mark on the alternator - last tooth of the trigger wheel is 180deg before(or after) VR-sensor. But unable to find any info in manual.
jac_is_smiling
Bike owned: Cagiva Planet, NC23 x2, FZ 600
Post by jac_is_smiling »
Im sure I remeber reading thats the firing point at idle. Used with a strobe to check the ignition timing/advance.
