Removing swingarm
TJenkos
Removing swingarm
Taken the spindle out but have that threaded cap in, how do I remove this?
Ta!
Ta!
Re: Removing swingarm
The one with the castellations or the large allen key? Have a look at the Workshop manual mate..
if memery serve right is a 13 or a 14mm allen key which i didnt have so i used a bolt 13 or 14mm, locked two 13mm m8 nuts off on the thread then used a 13mm spanner.CMSMJ1 wrote:The one with the castellations or the large allen key? Have a look at the Workshop manual mate..
perfect homemade too :)
14mm then - I got a large sump key that was right! Halfrauds FTMFW innit.
TJenkos
Removing swingarm
Genius, idea copied and used successfully! One swingarm removed!!porndoguk wrote:if memery serve right is a 13 or a 14mm allen key which i didnt have so i used a bolt 13 or 14mm, locked two 13mm m8 nuts off on the thread then used a 13mm spanner.CMSMJ1 wrote:The one with the castellations or the large allen key? Have a look at the Workshop manual mate..
Why Thank you tom,
my dad said the same thing when i did it?
i got a proffesional set of high tensile allen keys and the biggest i had was a 12mm and ive never used it,
so as i said used the head of a bolt and improvised :)
- Deviant400
smart arse
viewtopic.php?f=62&t=27307
