Ignitech CDI and tacho question
Now i know you cant use a 30 tacho on a 35 with the standard CDI and vice versa but does it matter if your using a ignitech??
Reason for asking is that the 30 tacho comes as a seperate unit where as the 35 comes as a complete unit with the temp and speedo attached, ive swapped the 35 internals over to the 30 housing before but it was a pain in the arse to be honest and rather not do it again.
Re: Ignitech CDI and tacho question
Ignitech 30 and 35 are different connectors on the boxes..but whether that stops them working if you sort hte wiring.???? I dunno
Cammo
Post by Cammo »
Drunkn Munky wrote:Now i know you cant use a 30 tacho on a 35 with the standard CDI and vice versa but does it matter if your using a ignitech??
Good question.
I reckon the ignitech would be specific to each model tacho, but maybe best to ask the company?
