Carb sync
yazza54
Carb sync
Post by yazza54 »
How on earth do I get to the front right screw to attach my carb pro?
yazza54
Re: Carb sync
Post by yazza54 »
Never mind found it.. Was expecting it to be in the inlet tract like the rest. Well it is in the inlet tract but in a different place.
skinnydog0_0
Bike owned: Penny Farthing
Re: Carb sync
Post by skinnydog0_0 »
Do you mean C4? as in front right as you sit on the bike?
If you do it's the easiest one to get to as it is just below and right of the thermostat housing ;)
yazza54
Re: Carb sync
Post by yazza54 »
Yeah I was looking underneath.. Doh!
skinnydog0_0
Re: Carb sync
:grin: yer i did exactly the same
yazza54
Re: Carb sync
Post by yazza54 »
This is doing my head in. 4 &2 are off the scale. 1 & 3 are 1/4 the way up. So I've tried to back 1 &3 off but nothing seems to be working. One minute turning a screw out slows it down, then the next it speeds it up! What am I doing wrong?
It's now ticking over at 4k without the bloody idle screw.
skinnydog0_0
Re: Carb sync
Are you doing 30 or 35 carbs?
Did the bike idle okay before you started?
yazza54
Re: Carb sync
Post by yazza54 »
skinnydog0_0 wrote:Are you doing 30 or 35 carbs?
Nc30, it idled at the correct revs but was lumpy and the readings were miles out. I'm using a Haynes but it doesn't actually tell me anything about which screw does what and which way to turn them. Total chocolate fireguard!!
skinnydog0_0
Re: Carb sync
You need to get No2 + No4 sync'd Single adjuster - then sync 1 to 3 Adjuster next to Cylinder1 - then sync 1 and 3 to 2 and 4 by using the adjuster next to Cylinder3.
Are the carbs seated properly?
Are the adjuster screws moving freely, and are you making sure you are not pushing on the screws as this will make the revs rise?
make an adjustment and blip teh throttle and let the revs settle, then see where you are.
yazza54
Re: Carb sync
Post by yazza54 »
Just make sure I've got my numbers right
If sat on the bike..
2 4
1 3
