Shorter side stand (NC30)
OK my wifes bike is now up to my knees as its been lowered using both the rear hub and the RO lowering kit.
This has significantly changed the geometry of the stand and the bike does not lean when on the stand making it unusable .
Does anyone know of a shorter stand that will fit or is it a cut and weld job?
- Bike owned: CB-1, MSX125
Re: Shorter side stand (NC30)
This is the length of a 92-9 cbr900 stand.
I got one as it's about 20mm longer than a CB-1 stand which was useful as I raised my CB's tail. So I have a spare CB-1 stand if any use.
It's about 20cm long. I will measure it if looks useful but I'm not getting my fingers dirty for nothing
As you can see in that picture they both use the fairly standard Honda rotary switch and the same bolt mounting method. Believe it's the same for the 30?
This looks like its a good fit the NC30 stand is about the 22cm bolt to ground.
Could you confirm the length please as 2cm off standard would be about right.
How much do you want for the stand?
- CRM
Tricky to get a descriptive picture I'm afraid.rossman_999 wrote:This looks like its a good fit the NC30 stand is about the 22cm bolt to ground.
It's @20cm to the bolt centre on the short side and 21cm on the long side, if you see how the "foot" is at an angle?
£15 posted (RM first) is good if ok with you? Drop me a PM please.
