Liner overbore on an NC29 engine.
Crazy_German
Bike owned: CBR 400 RR NC29
Post by Crazy_German »
Hi Guys,
I´m actually tuning my NC29 engine and have one important problem:
I´ve ordered an 444cc big-bore-kit from JE-Pistons. The Standard Pistons have an bore diameter of 55 mm. The JE-big bore pistons have 58mm.
I´ve talked to my mechanic which should do the bore of and he said it is possible that I need other liners because there could be to much material to machinend out of the installed liners.
Does anybody here have knowlede about the bore of from an NC29 engine?
selexon
Bike owned: FZR400R 2TK, CBR400RR NC29
Re: Liner overbore on an NC29 engine.
Post by selexon »
I just check out the sleeve and it had to say what the sleeve thickness is. You may have to push a sleeve out to see if you need to make new ones or get the std sleeve bored.
Might be worth while to try LA Sleeve for some new ones. http://www.lasleeve.com/master.html
