LED flasher unit
LED flasher unit
I need a flasher unit to fix the flash rate of my newly installed LED indicators. Since I can't seem to find anyone here in N.Z who stocks them I want to buy one of ebay. The problem is that my stock flasher unit on my nc35 has three small pins parallel to each other, and the ones on ebay seem to look similar but they are only 2 pin.
MY question is, will they work for my bike? Surely there must be some nc owners out there that have bought these things off ebay and can help me out with their experience.
Thanks.
Thanks.
Re: LED flasher unit
I bought a 3 pin relay off ebay.
You'll need to chop the plug off the rvf harness and fit some standard female spade connectors to plug into most aftermarket units.
As above; there is a +ve in a flashing +ve out (that goes to the indicator switch) and an earth. I'm pretty sure that the 2 wire/pin units are just missing the earth.
One of my Honda's has a 2 wire unit where there was previously a 3 wire setup & it works fine.
Phil
Phil
Brilliant. Thanks guys
- Bike owned: NC35
i bought an inline 3 pin led flasher unit that fit directly in without any mods off ebay a few months ago...so just look on there
