Rusty Tank
dunk400z
- Bike owned: VFR400Z
Rusty Tank
OK last year I replaced all the carb stuff and that's as far as I got. It's a new year and decided to have another go starting with the rusty tank. So far took tank off and tried to get the rust coloured petrol out - easier said than done! Cleaned out the diaphgram and seems to work OK but only a trickle came out so took the whole tap off (now looking for a new o-ring). Bit I'm stuck with is the gauze flter that did not come out with the tap - does it come out as it looks pretty gunked up - anyone else done this? Finally, what's the best way to clean out the tank or should I bother and just fill it up and hope for the best - it would be a shame to have to clean carbs all over again!
- Hadies
Re: Rusty Tank
This may be of some use to you;
viewtopic.php?f=24&t=25775&p=185199&hil ... 300c#p1851
dunk400z
Re: Rusty Tank
Thanks for the link - also managed to get the gauze filter out by pushing it back in to the tank and fishing it out of the filler hole - so far so good. Like the idea of using a bike chain to knock the rust off from inside but still not sure how far to go with the suggested rust eating chemicals and resealing the inside afterwards - is it worth it - anyone done this?
dunk400z
Re: Rusty Tank
Tried the Gold Standard Tank Sealing Kit off eBay and it worked a treat - if you've got the patience to sit and rotate the tank over and over in all directions then I would recommend this. The actual tank sealing stuff is pretty good but don't forget to take everything off and plug all the holes! A wine bottle cork fits great in the fuel tap hole but the fuel cap hole is more of a problem to seal!
and the good news is the bike started this weekend for the first time in 5 years and sounds pretty good :)
gpz900
- Bike owned: GPZ900, NC30, NC35, NSR250SE
Re: Rusty Tank
Vinegar works surprisingly well, but you need to coat it with something after or it will probably start to rust again.
I used a product called Tank Kreem on my GPZ900. The de-rust solution didn't do as good a job as vinegar but the coating part seems ok. So far.
Useless trivia:
Probably safe on the NC, but the GPZ has internal breather pipes, so when I tried the "length of chain" method for loosening the heavy rust the chain got tangled around the pipes. It was the mother of all bitches to get out.
Nice one.
Al.
Useless trivia:
Nice one.
Al.
