CDI
- geebus
- Bike owned: 1990 VFR400 NC30 + SV650s
CDI
Anyone used these lovely cheap things from hong kong?
http://cgi.ebay.co.uk/Derestrict-CDI-Ho ... 2503wt_907
Think i might try get a programmable one but just wanted to know if anyone had actually bought one seeing as they are quite cheap. and that normally means nasty.
You get old bikers and bold bikers, but no old bold bikers
- Gavin jap4
Re: CDI
had a customer the other day telling me his bike blew up using one of those
- skinnydog0_0
- Bike owned: Penny Farthing
Re: CDI
I had a very similar one on my 35, and it over revved and dropped valves in C1 and C3, if you can get a programmable one
Username
- Bike owned: VFR400RK, VFR750FK, VFR750FH,
Re: CDI
How did the bike go before YOU over revved it? At what revs did the valves drop?skinnydog0_0 wrote:I had a very similar one on my 35, and it over revved and dropped valves in C1 and C3, if you can get a programmable one
reverse cylinder jim
Re: CDI
Ive run one of these units back to back with a standard unit on the dyno and there was no difference's at all between them except the non standard unit didn't have a rev limiter! or should i say the dyno operator shut off before one was found due to mechanical sympathy.
- skinnydog0_0
Re: CDI
I have to say the unit i used was very different to the standard unit. with the jetting i had the standard CDI was very flat at 11.5 to 13k but the chinese one revved all way till you let off the throttle. I have to say this doesn't make it any better, it just masked fueling issues.
To answer your question, i think it was revving to 16k + once the red mist falls and you are desperate to overtake you tend not to notice the revvs going up and up, if it keeps pulling you keep twisting (very very dangerous and expensive
I would sure recomend a programable CDI and having the bike set up on a dyno by someone that knows these bikes. it is likely to save you lots of time and money in the long run
Re: CDI
ignitech
