Front brake lever action stiff
arsey30
Bike owned: ftr223 650 bros
Post by arsey30 »
The brakes on my NC30 work reasonably, but the lever action is not as light as others I have tried and the lever is sluggish to return, not coming back instantly with a click as normal.
I have cleaned the caliper pistons externally and they go back with hand pressure and the discs are not binding, the wheel spins freely.
I have cleaned and greased all the lever pivots and replaced the master cylinder seals, piston, spring and boot, but action is the same.
I will bleed them again, and perhaps remove caliper pistons and seals to clean properly, but the pistons retract OK now.
Any one had this problem before?
Dave.
porndoguk
Re: Front brake lever action stiff
Post by porndoguk »
check the screw that mounts the lever to the perch isnt a tad to tight, i adjusted mine the other day as it felt a bit loose, if you go to far it will stick.
hope this helps dave
Rick
Cammo
Post by Cammo »
I've had this problem before, a new master cylinder sorted it.
I tried a rebuild kit for the master cylinder first, but it didn't help, the bore may have been scored or worn.
Worth looking at perhaps. Try swapping it with a spare master cylinder before buying a new one?
