nc30 fork replacement?
cragionvfr
Bike owned: NC30, ZX7R
Post by cragionvfr »
140533914883
Not sure if these are anyones on here? Would they be a good upgrade for my NC30?
jim157
Admin NWAA
Admin NWAA
Bike owned: A few small ones
Re: nc30 fork replacement?
Post by jim157 »
Here's the link.
Seems expensive for a pair of forks that you'll probably have to revalve & respring because of the weight difference between the RGV and the NC30. You'd be better off rebuilding/uprating your standard forks for a lot less money.
If you really want usd forks, there's probably several better options available than RGV forks.
AUTOEXEC.TWAT
cragionvfr
Fair enough! Thank you very much!
lizard821000
Post by lizard821000 »
very true^
personally id just fit ricks upgrade kit and have the suspention set up properly with the money youd save.
cragionvfr
Best get an email sent to rick then! Im only looking as I had a trackday at mallory last week and the bike just didnt feel right even after asking advice on set-up. Suppose after 45k of abuse, its feeling a little tired and im pretty sure the only work done to the forks would be oil and seals. Now you saved me some money on the forks the shock is probably the place i need to start as that was even worse!
