Exhaust question
The_Doctor
- Location: Newcastle mostly, Newark on Trent occasionaly
Exhaust question
Hi all....ive asked this question before on the old forum but didnt get any replies so here goes again...
what end cans will fit an nc30? they look pretty universal and ive read on here before (not sure which topic) that someone had put a can from another bike on thier nc, iirc it was one from a bike that had the exhaust exit on the other side and the person was able to buy a slightly scuffed one and fit it to the nc on the other side so the scuffs faced the wheel, bargin solution!
i want to know which ones will fit straight on or with a little persuasion so i can keep my eye out for a nice one at good money. being able to look out for other models and not just nc30 ones widens the choice and will give me a better chance at getting a bargin!
thanks in advance!
thanks in advance!
fastdruid
Re: Exhaust question
The trouble with the NC30 is that the collector and silencer is one piece you either have to cut the pipe or fit a full system, as such nothing is simple to fit. :/
If you have already cut it and it is fitted with a link pipe and aftermarket can already then there are loads of pipes that should fit, simply measure the external diameter of the link pipe where it goes into the silencer. Then when you have that you can fairly easily look up what other cans should fit or ask any seller what it is.
Druid
Druid
The_Doctor
Thanks yeah mine is already cut, i have an art can at the moment but its looking a bit tatty so looking to replace it, is there much difference between exhaust diameters? i thought they would be pretty similar.
do the diameters of the actual can vary that much too? as this will affect the strap etc...
fastdruid
For ease of making most are pretty similar, around 50-52mm into the silencer IIRC. While the external dia of the silencer itself may vary between makes most of them come with their own strap anyway. Those that dont you can get the straps pretty easily.
Druid
Druid
The_Doctor
cheers druid i will have to get my measuring stick out and take a trip to the next auto jumble...
