speed light on clocks? nc24 jap import
jimmy400notts
Post by jimmy400notts »
Hello , i've recently brought a vfr400r nc24 that is a Japanese import and im wondering what this red light indicates on the clocks it just says speed. what does it indicate? any info much appreciated, cheers, Jimbo
Re: speed light on clocks? nc24 jap import
It indicates that you are travelling above 80km/h. Nothing more.
veefer400
Bike owned: Ducati 900SS, 1978 Cafe 400/4
Post by veefer400 »
Stick some tape over it - mine gave me heart failure every time it came on in a red oil-light-stylee :shock: :grin:
kickin
Bike owned: VFR 400 NC24, Yamaha XJ 600 S
Post by kickin »
Japanese models have a speed limit of 180kph the red light should come on when the limiter is active. If you have a limiter you can overcome it by fitting speedo converter (kph to mph on the cable) or cut the black/White and blue/orange cables and fit a 2k resistor between them on the harness side. But I will say I have not tested as mine still in project phase.
:rocks:
gissmo50
Bike owned: nc24, Cb400n Bobber, Xj600N
Post by gissmo50 »
The nc24 is not restricted as neo said the light just shows when you are going 80km/h or faster
kickin
Post by kickin »
Honda shop by me said some privite imports were restricted. So are all NC 24 not restricted. And sorry if I have misinformed you. :cry:
Hey it's an honest mistake and there is a lot of mis-information on the internet.
While it is true a lot of the JDM bikes are limited to 180km/h (112mph) this law wasn't in effect when the NC24 was made, but at the time the maximum permissible speed of a motorcycle legally on a public road such as express way was 80km/h, this light was to let you know that you are exceeding that speed.
In standard form with the light the NC24 isnt restricted, it will run off the clock to about 125mph.
The NC30 and NC35, along with the ZXR400 (89 onwards bikes) were limited to 180km/h.
Hope that helps
kickin
Post by kickin »
Yeah helps alot. Thank you Neo
:smile:
jimmy400notts
cheers fellas
thunderace
Bike owned: R6, YZF600R
Post by thunderace »
I can lend you a pair of needle pliers to pull the bulb out with :grin: Those rubber holders can be a pig to get out :twisted:
