NC 24 Exhaust can
BigDonk
NC 24 Exhaust can
Post by BigDonk »
Any advice on Exhaust cans for the NC24?
the exhaust (one piece) end can is going a bit flakey on the wheel side of the can, ie has penetrated the outer metal cover, does appear to be holed, when the bike was running but I do not think its far off.
Donk
Re: NC 24 Exhaust can
You can get a link pipe for the NC24 pretty easy. I may even have one knocking around.
This will give you a normal exit pipe to which you can bolt on most slip-on cans.
From then on it is whatever takes your fancy / how much money you want to spend.
There are a few Japanese cans that have integrated link-pipes like the standard exhaust, DIC / Over come to mind but these wont be as easy to find.
spooky
Bike owned: nc24
Post by spooky »
Or you can take the outer covering off with a grinder and polish up the inner part. its all stainless steel under the outer cover and polishes up real well.
heres a pic of mine when it was polished a couple of years ago, and it has'nt changed or gone dull yet. just a wee rub with solvol now and then to shine it up like new.
there is a small drain hole on the underside but you will hardly notice it. I do wonder why honda put the tin cover on in the first place as i think it looks better without it.
BigDonk
Post by BigDonk »
thanks guys
Spooky
I will have a look to night, your tip sounds a plan
spooky
Bike owned: nc24
Post by spooky »
well did you? :?: :?: :?:
thunderace
Bike owned: R6, YZF600R
Post by thunderace »
spooky wrote:I do wonder why honda put the tin cover on in the first place as i think it looks better without it.
It's designed to be a heatshield so your pillion doesn't melt their boots ;)
Stewie
Bike owned: Honda NC24
Post by Stewie »
spooky wrote:Or you can take the outer covering off with a grinder and polish up the inner part. its all stainless steel under the outer cover and polishes up real well.
Bloody hell, that can looks wicked, how did you get such a neat finish ? I mean I know its polished but you must be pretty accurate wih the grinder, nice one.
And this one fades in quietly......
FB Stew johnstone, add me if you want :)
connor73
Post by connor73 »
mine was the same, looked like this
bought a carbon tube from egay and now it looks like this
spooky
Bike owned: nc24
Post by spooky »
It was easy as there are only a few stitch welds to grind, then dress them up with a medium sanding disc, moving on to a fine disc, then onto a polishing buff with the medium soap/bar, then onto fine polish.
3 hours work max.. you can go to mirror finish if you want but it would take too long and its not really worth all that effort.
spooky
Bike owned: nc24
Post by spooky »
connor73 wrote:mine was the same, looked like this
that looks well mate, like that colour scheme.
Get the wheels painted up and show it in performance bikes mag. they are looking one in an original paint scheme for an article,but you need to lend them your bike for a wee while!
