Has this happend to you
- Bike owned: nc30
Hi all.
Spent a bit of time today giving the a nc a good service ready to go out on.
All done one last thing to check the tyre pressures,
Toped them up with air guess what? The valve on the front wheel came completly out what a downer just set me back onother week before I get chance to take the wheel of & take it to the shop for a nee valve.
Anybody come across this?
Cheers.
Rob.
Cheers.
Rob.
Re: Has this happend to you
ive seen it a few times, its the rubber when it deteriorates, goes rock hard and you can literally touch it and it will snap off
- CRM
always checked at the MOT - or should be, but yes had one fail in a similar manner
- uber pikey
Mine has been rock hard quite a few times but has never come off in my hand, I think you are pulling too hard.Simon_Ed wrote:ive seen it a few times, its the rubber when it deteriorates, goes rock hard and you can literally touch it and it will snap off
I saw it so I took it!
- CRM
Oooh suits you sir.uber pikey wrote: Mine has been rock hard quite a few times but has never come off in my hand, I think you are pulling too hard.
- Sligeach
Reputable tyre changers will always change the valves with every tyre change.
They are not even that expensive. I always see a note of it on the invoice from FWR
- Speedy
- Bike owned: RVF400RR, ER6n
It's apparently more common than it seems and considering the potential catastrophic consequences, if it comes off when you're riding, I'd say a new valve with every tyre change is an absolute must!
My Bandit was left unused for about a year and I recently noticed that one of the valves was leaking air through the rubber bit too; needless to say that was replaced sharpish!
http://cgi.ebay.co.uk/4x-SNAP-IN-TYRE-V ... 6911512652
I have these fitted (again changed whenever the tyres are)
Being angled makes it a lot easier to fit air into the wheel which puts less stressses onto the rubber as when they are uprighted it takes a lot of bending them to connect up the airhose
- Bike owned: nc30
Thanks guys.
ye it is a blessing that it didnt happen when I was rideing it & a good warning to give them a good check somthing that you might over look.
Cheers.
Rob
Cheers.
Rob
- Bike owned: nc30
Thanks for you're replies.
Could somebody tell me whats the best front stand for the nc30 to get the wheel off.
Thanks.
Rob.
Thanks.
Rob.
