RS250 shock replacing on nc30????
- Bike owned: HONDA VFR400R NC30
hi all ive been chatiing to someone about a rs250 shock.... aparently straight swap for mine? are they better than nc30 one? shurley the nc30 shock is made to be better than a 250 one???? anyone fitted one to there nc30 if so can i have a bit of insight into fitting? and pro's and con's????
Re: RS250 shock replacing on nc30????
the survey says..do a search dude..
bottom line - they are not a straight fit, they need a minor fettle
they need, ideally, revalving and respringing.
If it ain't broke, don't fix it!
- Bike owned: r6,fzr 400
hi, me and my son fitted a gsxr 600 k6 k7 all we had to do was take about 2mm of the top collar on the shock , we also had to cut part of the battery box but did not molest it we just cut small bits of at a time. hope this helps and by the way what an improvement its made. cheers gary
hi have u fitted to a nc30? n if so have u gt any pics as i wud be intersted in this mod
hi , yes fitted the gsxr shock to the nc30 i will take some pics over the wknd.if you ask me its alot easier than trying to fit the cbr shock.
Its worth noting that you will need a stiffer spring on both thr gsxr and cbrRR shock if you fit them to a NC. Linkage rates are much different on the NC which needs a heavier sping to work properly.
- Hadies
Drunkn Munky wrote:Its worth noting that you will need a stiffer spring on both thr gsxr and cbrRR shock if you fit them to a NC. Linkage rates are much different on the NC which needs a heavier sping to work properly
- Trinirides
- Bike owned: NC30 is all you need to know
Links:: http://www.hondarvf.com/workshop/modifi ... dification
Shock spring info and prices:: viewtopic.php?f=22&t=20310#p139912
