1WG rear brake calipers.....
alext
Im currently fitting FZR400 running gear (wheels, forks and brakes) to my 350lc.
I dont have an FZR400 1WG rear brake caliper, and the supply of them from thief-bay appears to have dried up.
does anyone know what other bikes use the same rear caliper?
second to that, what axle diameter/rear disc diameter has an FZR400 3TJ got?
if the disc is the same and the axle is the same, an underslung caliper would give me more room to play with and also make the torque-arm situation a bit easier.
thanks for any help
ALex.
thanks for any help
ALex.
Re: 1WG rear brake calipers.....
The disc is 210mm
alext
any chance you could measure the rear axle diameter?
ta
ALex,
ta
ALex,
Taggyd
i think ive got a caliper...somewhere! took it off when i converted to 17" rear, Ill see if i can find it if you're interested!
- Kayla850
- Bike owned: Sunn Tzar S2
The 3TJ rear axle is 20mm.
www.projection-racing.com
www.pjcfasteners.com
Taggyd
did you really post that at 2.50am?
My puter says 3:50 amTaggy wrote:did you really post that at 2.50am?
Taggyd
the forum clock is an hour ahead!
- Hogdigerdy Dog
still bloody early whichever it is
may i recommend ovaltine or horrlics of a evening, you'll be out like a light
- Kayla850
Yeah... The joys of being self employed- you wake up in the middle of the night and can't get back to sleep!
