R1 04/05/06 rad into nc30?
- pauliealdridge69
- Bike owned: Nc30,35,998s
Has anyone ever tried to put an r1 rad into an nc30 or does anyone have any recommendations for an upgrade with out spending 550 on aluminium upgrades? Bike is for road use...
Cheers for any advice.....
Paul
Paul
- royster81
Re: R1 04/05/06 rad into nc30?
i think you'll have some problems with front head - front wheel clearance but go for it, i'd love to see someone do it.
- pauliealdridge69
Think ive found a good one.....the air flow to the carbs on the nc30 all go over the top rad don't they? so if i had only one rad then i guess i would just need to make sure the gap at the top was the same to insure correct air flow...was thinking about ram air but i dont need get the speed up anymore for road use! would just like to help keep temperature stable and lower on longish runs....i see people have fitted r6 rads with no probs really....think i'll have a good look and go for it....do you think the standard water pump will be plenty to push round it or would i benefit from a pump? as i say its not gonna be raced flat out for ages....just road use
- royster81
i couldn't see why the stock pump couldn't pump the fluid but i'm sure there is someone on here would know for sure, have you any pictures of the rad in place
- Martin
I can't see how you'd get it to fit without it fowling the front cylinder head.
Too spensiff!!!
Martin wrote:I can't see how you'd get it to fit without it fowling the front cylinder head.
A single bigger rad will never fit!
- Martin
I spelt fouling wrong. If you spelt it the way I did the first time you defnately wouldn't get it to fit. I don't think you're intending on catching ducks in your Rad are you?
Too spensiff!!!
Alex_ludd
- Bike owned: Giantco 125, ZZR400n , NC30
i think you just invented a new blood sportMartin wrote:I spelt fouling wrong. If you spelt it the way I did the first time you defnately wouldn't get it to fit. I don't think you're intending on catching ducks in your Rad are you?
