Motrax Mini Indicators on a 4DX/3TJ?
VForcer
Bike owned: NC30, CBR6, Blade(2), FZR400RR
Post by VForcer »
Not usually one for deviating from standard parts too much, but after fitting Motrax mini's on my '97 Blade they just made it look miles better :peace: (IMO of course ;) )
So, the indicators on my FZR400 are a tad bulky and i'm thinking i may well change them for smaller/neater units from Motrax (they can always be swapped back should the originality bug come and bite me!). Anyone got them fitted? I can't see that Motrax make specific blanking plates for the 400's.
Anyone give me a heads up on what i can use, if anything? :smile:
Cheers,
Rob
Re: Motrax Mini Indicators on a 4DX/3TJ?
Post by Evilchicken0 »
Mine has small oval type with clear lenses. You don't need a blanking plate because they fit through a hole in the fairing and on the mudgaurd at the rear.
You need the longer stemed ones for the front, the picture shows them with short stems and they only just reach the mounting plate
It really is a nice bike that TJ of yours Boris.
I remember a few threads back in the day about it but is there any up to date info on it? it is well fettled and sorted innit?
8-)
VForcer
Post by VForcer »
Nice one EC, i shall bear that in mind - although yours doesn't look 3 bad with the shorter ones on ;)
It was until it was clipped by a car that batterred the can and twisted the rear subframe a little. I've got all the bits to go on it now ... and then a few more I just haven't done it.
I'll have a go at it again in March when the weather warms up.
It's a standard 3TJ with:
Bembo radial master / goodrich hoses / standard calipers / ebc hh pads.
SP forks
EMC rear shock
Supercorsa pros (part worns)
520 chain and sporkets
There's a Baglux tank cover and tank bag
DB skidmarx screen
Extra padder pillion saddle (for Significant Other)
DHM Footpegs
I've got lots of bodywork atm so I'm going to make a good set with all the stickers for a change !!!
I ought to do a 600 conversion but the Bimota always seems to soak up my time and money
Taggyd
Bike owned: fzr 400 3tj x 2, cbr900rrs
Post by Taggyd »
if you have a rear right side panel left over from your bits let me know, i need one! :grin:
I'm sure I will have
Kayla850
Bike owned: Sunn Tzar S2
Post by Kayla850 »
Evilchicken0 wrote:Image
That's a really nice bike :grin:
www.projection-racing.com
www.pjcfasteners.com
Ta Luv ... how's the hybrid coming on ???
Kayla850
Post by Kayla850 »
Evilchicken0 wrote:Ta Luv ... how's the hybrid coming on ???
Ok-ish. It's a pain because I can't move the heavy stuff without my bf's help :x It should be done soon though, it's a case of finding the time to make the engine plates up then assembly is simply the reverse of disassembly :whistle: I should've stripped the 3TJ right down and left the 600 lump on the lift rather than listen to my bf and jack the lump into the chassis. Ah well, lesson learnt, I'll know for next time :lol:
