Exhaust spring length
- matt_vfr
- Bike owned: '89 NC30
Guys,
Trying to sort out my ethos exhaust at the moment, but the exhaust springs are completely knackered (falling into rusty pieces or overly stretched so they dont coil up properly). What length of spring should i go for when replacing these? The distance between the eyes on the system is approx 10cm. Is there a standard length ratio to go for? Any advice on particular type to get?
Thanks for the help :D
Matt
Matt
- ibby4585
- Bike owned: SP's
Re: Exhaust spring length
I might have a couple laying about somewhere Matt . If not eBay have replacements I think they are 8 to 10cm in length.
Kris
Kris
- superlite
- Bike owned: TLS, LB80 x 2
I use Tyga springs on my Ethos with no probs - they are stretched a little more than they would be on a Tyga system though.
'Take it to the Back'
- BillingCBR
I used 83mm springs on my TSR system, and one of the spares went on the SP1 style system with no problems
- Cru Jones
- Bike owned: NC35
Speaking of exhaust spring length...what length springs do you guys use for the Maggot and stock headers?
- superlite
There are no spring mounts on the stock headers. You could get some welded on at a location to suit whatever springs you get.Cru Jones wrote:Speaking of exhaust spring length...what length springs do you guys use for the Maggot and stock headers?
- matt_vfr
That's great Kris, if you have a set of 4 that will give enough tension at 10cm then ill send a few readies your wayibby4585 wrote:I might have a couple laying about somewhere Matt . If not eBay have replacements I think they are 8 to 10cm in length.
Kris
Matt
- Cru Jones
- Bike owned: NC35
True, the stock header isn't designed to be used as such, but there is one spot where you could attach one spring, no? I'm guessing someone's done that before and would know which spring they used.superlite wrote:There are no spring mounts on the stock headers. You could get some welded on at a location to suit whatever springs you get.Cru Jones wrote:Speaking of exhaust spring length...what length springs do you guys use for the Maggot and stock headers?
- ibby4585
- Bike owned: SP's
I've only got one spring I'm afraid mate
But it's 8cm in length
Kris
Kris
