NC30 speedo not working !
vfrjim
as title , speedo not working any ideas of what may be causing this ... its still attached to clocks tho
thanks for your time
Jim
Jim
Re: NC30 speedo not working !
Hi Jim, usual cause is the at the gearbox end. The speedo cable gearbox uses a plastic adapter to the bike's transmission, this can get chewed up (fairly common on nc30's and other hondas).
Undo the 2 bolts for the speedo cable gearbox on the engine side cover and inspect the plastic part. It could purposely be made a weak link to prevent damage to the cable or speedo unit. Might be worth also fitting a new cable or lubing your existing one, this damage may be caused by resistance in the cable.
It's part 29 in this diagram:
http://www.akhara.com/nc30/nc30parts/files/20.htm
HTH
HTH
- banoffee
mine stopped working a while ago, was the speedo cable (had snapped). easy fix
