Rose Joint Size
Hadies
Rose Joint Size
Post by Hadies »
Hi all,
I need a female rose joint for the gear change pedal/linkage. Whats the internal thread size and I suppose not as important, but the approximate size of the hole in the ball?
Hadrian
RonniB
Re: Rose Joint Size
Post by RonniB »
Hi there,
It's M6 tread, but it needs to be lefthand in one end (can't remember which), and the hole in the ball is also 6mm (suited to a M6 bolt).
try a place like rodends.co.uk if you struggle to find it.
Ronni
