NC30 Fuel Filter
Elbad
- Bike owned: VFR400 NC30
NC30 Fuel Filter
Hi,
I'm trying to locate the fuel filter on the nc30.
I went to a local bike shop and they gave me this fuel filter :
I can't find where to put it. The manual says its by the fuel tap. Theres some pics I took:
Is the filter there somewhere (do I just unscrew everything? Or is it a built in filter?
Any advice will help out. I want to put it back together today still, for a morning test run tomorrow.
Re: NC30 Fuel Filter
its a built in filter inside the petrol tank pal,
there isnt really room for a filter, i bought some and couldnt fit it in so left without on,
also there are 4 FILTERS on each of the float valves in the carbs so you efectivly have 2 filters to each of the carbs any way.
dx400r
As porndog says...
There isnt a fuel filter like that one as such on an NC30 so hopefully you didnt waste too much time looking! There is a basic strainer type one inside the tank behind the fuel tap.
Sorry i made a typo on that, there are 4 Aditional Filters on the bottom of the Float valves,porndoguk wrote:its a built in filter inside the petrol tank pal,
i put there are for floats on the floats! brian freeze
so as i meant there are two filters before the fuel gets to the carbs.
Elbad
So I should take apart the bit in the photos and just clean out the strainer inside it then?
yeah undo the 3 8mm headed m6 bolts, and give the filters a good clean with carb cleaner be carefull as they are fragile,
make sure the tank is empty before you remove the tap btw.
- Smev
- Bike owned: NC30 of course
Hi mate, the filter the bike shop gave you can be fitted in-line with the fuel line.
Once the fuel leaves the tap through a black hose, it can be fitted by cutting the hose and slotting it in there. I had one fitted on an old NC30 I had once.
But as said you can just take off the fuel tap and give that a clean inside.
Mister Donut Rep NC30
amorti
- Bike owned: CB-1, MSX125
I had a fireblade where the in-tank screen had perished, split and wasn't doing a job anymore. So instead of paying Big H's silly prices for a new one, I bought a universal filter and stuck it inline on the fuel hose to the carbs. Only just barely enough room, but it worked fine - got to be better than the screen filter anyway.
http://i74.photobucket.com/albums/i264/ ... C00161.jpg
Maybe you can do similar?
