bros rear wheel fitment
Some time ago i had a bros rear wheel that i
modded to fit my racebike.
I let the guy have it when i sold the bike.
I bought another but its different and wont fit.
Does anyone know what model fits
i know theyre ugly and heavy but i only
want it for my wets
thanks
want it for my wets
thanks
Re: bros rear wheel fitment
How is it different to the other bros wheel?
- Bike owned: CB-1, MSX125
There were two different types of wheels used, but I can't imagine they'd have changed the locating hub?
Are you sure you didn't end up with a Revere wheel or something off one of the other similar shaft drive bikes?
They don't just bolt on - thye need modding first. I have one, am away now but I'll get a pic when I am back. Could even flog it...
The Bros also came in 400 and 650, not sure if there was a difference between them in wheels or igt was just a later model that had different wheels on it..
The later one was differentNeosophist wrote:The Bros also came in 400 and 650, not sure if there was a difference between them in wheels or igt was just a later model that had different wheels on it..
- Bike owned: v4's
The alignment/drive pins have different spacing is all. One is 85 pcd, the other 100. Just have the wheel drive pin holes drilled ($), or the hub modified ($$$$). Since the nc pins are closer to the middle of the wheel it will be fine structurally. I know of guys with Bros who go the other way with nc wheels and the pins end up out on the edge of the wheel.
being able to ride from point A to point B does not mean you have skills
