Page 1 of 2
Help installing angel eyes..
Posted: Mon Jan 31, 2011 12:01 pm
by iSparkzz
Well my LED strips arrived today, all i need help with is how do i wire them to my system to get them working?
Re: Help installing angel eyes..
Posted: Mon Jan 31, 2011 1:15 pm
by ludacris
i'm guessing you don't have a haynes manual...otherwise you could follow the wiring diagram
i'm gonna go out on a limb here and say the negative wire on the LEDs should go to ground and positive go to ignition (not to battery, otherwise the angel eyes will be constantly on)...sure someone will correct me if i'm wrong, can't remember the wire colours off the top of my head sorry.
Posted: Mon Jan 31, 2011 6:13 pm
by porndoguk
ludacris wrote:i'm guessing you don't have a haynes manual...otherwise you could follow the wiring diagram
or just wire them to the side light circuit/wiring so they only on when the side lights are on? that way they can be on or off. do bare in mind that the heat of the H4 bulb will eventually knacker the LED's
Posted: Mon Jan 31, 2011 6:21 pm
by Drunkn Munky
WTF are angel eyes?
Posted: Mon Jan 31, 2011 6:47 pm
by hallsie
Drunkn Munky wrote:WTF are angel eyes?
Headlights as you see on a beemer with the rings around the main lights
Posted: Mon Jan 31, 2011 8:30 pm
by graham72
Posted: Mon Jan 31, 2011 10:07 pm
by Cammo
There was a thread in the cbr section recently, might help:
viewtopic.php?f=28&t=19930&p=137536&hil ... es#p137536
Posted: Tue Feb 01, 2011 5:31 am
by ludacris
hmmm...wouldn't that mean that his angel eyes will be intermittent with the side light? not really the desired result...
if porndog's way works without flashing with the side lamps then that's an option along with what i suggested earlier..other option is to wire them to the low beams so they switch off when hi beams are in use and last option would be to use an on/off switch in the circuitry if you want personal control using the ground & ignition power method i mentioned before
i would highly suggest you get your hands on a wiring diagram bud
Posted: Tue Feb 01, 2011 6:04 am
by Cammo
ludacris wrote:hmmm...wouldn't that mean that his angel eyes will be intermittent with the side light? not really the desired result...
The side lights operate with the headlights, we don't use them in Oz (against regulations?), they're the bulbs in teh bottom of each headlight.
ludacris wrote:i would highly suggest you get your hands on a wiring diagram bud
:plus:
Posted: Tue Feb 01, 2011 6:55 am
by ludacris
Cammo wrote:The side lights operate with the headlights, we don't use them in Oz (against regulations?), they're the bulbs in teh bottom of each headlight.
aaaahh i see..learn sumthin new about these things everyday :grin:
